1994 toyota surf 30 Diesel ssrg Auto
got this with bad diesel knock took head off it was cracked so fitted a new one still the same .
so replaced the injector pump and injectors
also replaced ecu but still the same
changed fuel filter and housing still the same
If you rev it over 2000 rpm it is quiet
