i cant select 2wd,lights on dash are flashing as though its changing to 2wd but it does not disengauge 4wd.Might anyone know what the problem is,i think its more the electrical side of things.96 3.0 ssrx at :
4x4 box trouble
I'd start by checking out the vacuum pipe system. A lot of 4wd troubles stem from leaks, splits blockages etc. in there.Originally posted by ozziei cant select 2wd,lights on dash are flashing as though its changing to 2wd but it does not disengauge 4wd.Might anyone know what the problem is,i think its more the electrical side of things.96 3.0 ssrx at :
Have you tried rocking the car back and forth in and out of reverse?
Nevillef
tried that and the vacum seems to be fine.any other ideas? thanks ozzieOriginally posted by laser_jock99I'd start by checking out the vacuum pipe system. A lot of 4wd troubles stem from leaks, splits blockages etc. in there.
Nevillef
