Hi all
I've had my 3.0litre Surf for about a year now and would really appreciate some help and guidance re. the AC. When I first got the vehicle the AC seemed to be working normally, but for some time it has struggled to perform adequate cooling. The gas leaving the compressor seems cold enough and the clutch on the compressor activates when the unit is switched on, but doesn't appear to stay engaged long enough to do any useful cooling and cycles on and off every twenty seconds or so. What I would like to know, if anyone can assist, is:
1) Should the AC switch in and out at the compressor automatically and if so how often?
2) If so what controls this, ie.a control unit, timer or temp.sensor etc.?
3) What is the likely cause and fix of the problem?
On a different note, can anyone tell me whether a uk spec. Forerunner rear wiper arm supplied by the local Toyota dealer will fit my '94 SSRG vehicle.
Many thanks in advance for any help given
Nil Illigitimi Carborundum
