Help! whilst driving to town this morning the engine on my Nreg 3.0 td cut out and now won't start.IT turns over fine but won't fire all fuses are ok and there is diesel at the filter. any advise would be appreciated.
engine stopped
i'm no expert guys, far from it, but really cannot see it being plugs related, as one the engine has initially fired, they don't stay on long anyway..i'd say it was a fuel issue, and if it cut dead, but still turns ok, its probably something at the pump end? when you turn it over, does it sound faster than usual, as that may indicate a broken cam-belt, i think?
Hi I dont want to be the bringer of bad tidings, but this happened to me on a 2.4 and the cam belt had snapped.Originally posted by mickeyi'm no expert guys, far from it, but really cannot see it being plugs related, as one the engine has initially fired, they don't stay on long anyway..i'd say it was a fuel issue, and if it cut dead, but still turns ok, its probably something at the pump end? when you turn it over, does it sound faster than usual, as that may indicate a broken cam-belt, i think?
I had a look at the cambelt it appears a little slack but does'nt appear to be broken, also i loosened 1 of the pipes on the back of the injector pump and tryed to pump fuel through manually with ignition on no fuel appeared ,any new ideas anyoneOriginally posted by markyWhen an Engine just cuts out like this the first thing to check is the CAMBELT. Dont crank it over till youve checked this as you may cause more damage.
Thanks for the help so far everyone, i have taken the cambelt cover off the belt is not broken but is quite a bit slacker on the side away from the tensioner.could it have jumped a tooth on the fuel pump? if i turn the crank until the top pulley lines up with the mark is there also a mark on the pump pulley :Originally posted by BUSHWHACKERI had this exact same problem on my Transit diesel.
ther was an air lock in the fuel. In the end I had to loosen all the pipes connecting on to the injectors and crank the engine over until diesel was spurting out.
Been fine since.
Vince.
Happened to me once after I ran out of fuel then filled up. The car stopped later due to an airlock in the fuel lines. Quick pump of the fuel primer (on top of the fuel filter) and I was on my way again.Originally posted by wickenukThanks for the help so far everyone, i have taken the cambelt cover off the belt is not broken but is quite a bit slacker on the side away from the tensioner.could it have jumped a tooth on the fuel pump? if i turn the crank until the top pulley lines up with the mark is there also a mark on the pump pulley :
Hope it this simple for you!
Nevillef
timing marks all line up so cracked an injector and turned over the engine, no fuel at the injector i can only assume a problem with the injector pumpOriginally posted by laser_jock99Happened to me once after I ran out of fuel then filled up. The car stopped later due to an airlock in the fuel lines. Quick pump of the fuel primer (on top of the fuel filter) and I was on my way again.
Nevillef
quote:i'm no expert guys, far from it, but really cannot see it being plugs related, as one the engine has initially fired, they don't stay on long anyway..i'd say it was a fuel issue, and if it cut dead, but still turns ok, its probably something at the pump end? when you turn it over, does it sound faster than usual, as that may indicate a broken cam-belt, i think?
sorry m8 didn't read it properly before i replied
