Hi people, had my surf now about 6 months now, just wondering when is the best time to change the filters, oil,water etc.
filter change
About 5 months ago would have been ideal, never trust the previous owner or garage to do it.
Have a look here.
http://www.yotasurf.co.uk/forums/forumdisplay.php?f=27
Most people think an oil change every 5000km is good practice. Next time you reach a nice round number (e.g. 125,000km) do the oil & filter change. Then when you reach 130,000km you'll know it's due again. Easy.Originally posted by scouzzer1964Hi people, had my surf now about 6 months now, just wondering when is the best time to change the filters, oil,water etc.
Nevillef
I agree with the above. Never trust previous owner or garage.... First thing i did was all filters and oil (inc front & rear diffs, gear & transfer box)
Routine service.... oil every 3k miles or 5k km then oil & filters every 6k miles or 10k km.
if you do regular long distance runs you can stretch the service intervals but for the price of oil and filters its not worth the risk. Filters from milners are only about £12 for oil,air & fuel. If you go to a motor factors u can get a 25ltr drum of 10/40 semi synth diesel for around £30 (saves in the long run)BEWARE OF THE REAPER
Easy job, no trouble, take you about an hour all in including changing the oil and leaving it 1/2 hour to fully drain out.
Fuel filter can be difficult to undo sometimes and sometimes the oil filter will be tight however as long as those come undone easy then you will have no trouble, even if you have never wielded spanners before.
When you are draining your oil, run you engine for 15mins b4 dropping the oil as it will drain more and run easier.Originally posted by scouzzer1964thanks m8, may have a go the weekend if its not to cold.
B4 draining the oil make sure you can move the oil filter otherwise you will have to refill with new oil and waste it.BEWARE OF THE REAPER
