Hi there,
another noobie in the forum. Thanks a lot first for all the great advice. I moved to Rwanda in October and was looking for a good 4x4 to use here in Africa. My research was greatly helped by your site, leading me to order a 1994 SSR-X 3.0D from Japan. It is currently on the ship to Mombasa, where someone will pick it up for me.
Lots of people I talked to here said that the first thing that should be done when the car arrives is to remove the thermostat to reduce the risk of overheating. However, I wasn't quite clear on what the thermostat actually does and why the removal would help to avoid overheating.
As far as I understand, the thermostat regulates the use of the radiator? Is it true that when the car is cold, the thermostat allows the radiator to be excluded from the cooling cycle and then gradually includes it as the engine gets warmer? If this would be the case, I could understand why people would remove it - it never really gets cold around here
Lastly, I was thinking of buying a few spot lights to put them on the small bullbar the car comes with to amplify the high beam when driving on bad roads at night. Do you think this would hamper cooling in any serious waya? And would it be easy to connect these lamps such that they turn on when on high beam?
Thanks in advance for your help,
Nick
Rwanda
.Lastly, I was thinking of buying a few spot lights to put them on the small bullbar the car comes with to amplify the high beam when driving on bad roads at night. Do you think this would hamper cooling in any serious waya? And would it be easy to connect these lamps such that they turn on when on high beam?
Nick
Rwanda
thanks guys.
