Help!!!!!
Any of you who have dropped the front diff out for any reason - repair, diff drop kit etc.
If I undo the bolts but leave the driveshafts attached do you think it will drop a reasonable amount - 4 inches at least.
I've unbolted the sump pan on mine to get it off so that I can replace number 2 piston, unbolted the engine mountings, raised the engine as far as it will possibly go without bending the firewall, and I still can't get the f***ing thing out, need at least an extra 4 inches of space to get it out, possibly more.
I've also unbolted the steering stabilizer but not enough room, next could be the steering arm but that is a real b**ger.
Any ideas would be most welcome, I aim to get the car stripped and rebuilt this side of the next millenium if possible. (took 1 1/2 hours to get the sump bolts out and the sump loosened so this is a very long job).
Bummer! I was just getting the hang of it too
