Well s**t.
Took the head off yesterday having taken the rocker cover and camshaft off and found one of the valves sitting higher than the rest.
Well it's a bit worse than just a tappet shim.
So I now am going to be ordering for the second time a new head
New number 2 piston
Got to strip off the aircon rad and the sump, undo the con rod and push the piston out the top, replace it, refit it, then the new head.
So just a word of warning.
Don't drive the car even a few miles with serious tappet noise - you will stress fracture a valve which will then bang about inside the engine and trash the head and the pistons.
Luckily it didn't damage the bore at all.
Someone will have a great engine when I've finished though ther amount I've spent on it.
New number 2 piston
