My Surf has developed a ticking sound that I want to fix before I sell it - don't want to sell it on with any problems.
I've got two possibilities I think.
1. Big end bearings starting to let go allowing the piston to slightly tap on the head (it's not a heavy ticking at the moment). I have come up with this diagnosis while researching the Landcruiser as it is a known problem on the 4.2TD engine and gives the same symptoms.
2. Camshaft going soft causing a tappet noise due to wear - when I replaced the head last year, the camshaft sent with the head was damaged and because I couldn't wait to get the Surf back on the road, I measured up the old camshaft which was well within tolerances and fitted that. Quiet as a mouse when first fitted.
My questions to anyone out there are as follows:
1. Any other suggestions as to what it might be?.
2. If it is the Big ends, where should I get these from, chances are that I will have no luck with Toyota.
3. If it is the camshaft, any suggestions as to where I should get that from.
4. If it is the Big ends, has anyone changed these with the engine in the car - I presume that the aircon rad will have to come off and then be recharged.
I'm soon going to have a bit of time on my hands between jobs when I can get these sorts of things fixed.
: !!! Was prob running only 1/3 full and it got very hot! Strong engines those
