I started the head replacement today at mid day, thier are some very awkward bolts and nots that have to come out, which are not mentioned in in the head removal I printed off the group, it says remove the exhaust manifold, but does not mention that the bracket that is bolted to the left hand side and goes down to either side of the oil filter, has to have the top nuts removed and the bottom ones have to be loosened, to get at the bottom ones, you have to remove the wheel, remove the oil filter and have a suitable 3/8 drive knuckle to get one of the bolts out, well 5.5 hours later, had to stop my back was hurting to much....LOL I'm soooo unfit.
all I have to do tomorrow is remove all fuel injection pipes and some other stuff, remove inlet manifold, pully's timing cover, etc, I will keep you informed, I have also taken lots of digital pics and will do a detailed head swap on cd's if anyone would require one.
Will let you know how I get on tomorrow lads
