Off Road Mixed Surface
  • Off Road Mixed Surface
    Hi All
    as I've said, not done much off road stuff. Used to have a LWB Landrover, and did a bit in that, but Surfin is a different world.Landrover was stop stick it in low and go for it.Just like a tractor ( and about as comfy}.
    My questions are. On a mixed section, say hard surface, loose rock,grass and mud, how would you tackle it. 4WD from start , or wait till you lose traction and then 4WD.
    2) Mines an auto, On Steep downhill what is the engine breaking like ?
    3) Any general advice , Things Not to do etc. I,m scared of doing any damage.
    But it seems a waste to have such a great Off Roader and not to use it for what it was built for.
    Cheers Ron
    [QUOTE=Ronone]Hi All
    YOUR CHOICE
    My questions are. On a mixed section, say hard surface, loose rock,grass and mud, how would you tackle it. 4WD from start , or wait till you lose traction and then 4WD. YOU JUST PRESS THE 4WD BUTTON
    LOW BOX PUT IN L TAKE FEET OFF PEDALS & LET HER CRAWL 3) Any general advice , Things Not to do etc. I,m scared of doing any damage.
    DONT USE 4WD ON THE ROADS OR OTHER HARD SURFACE WHEN TRACTION IS GOODBut it seems a waste to have such a great Off Roader and not to use it for what it was built for.
    Look out for our next offroad days in the Northwest.
      Originally posted by Ronone
      Hi All
      Personally I would stay in 4WD on mixed surface. It takes a while to wind up the transmission. My first time a Devils Pit I stayed in 4WD all day and it was dry as a bone. No harm done.
      I usually select Low Ratio 4WD and L on the gear selector. It's a good crawler gear.
      Don't select 4WD on the motorway (at over 50MPH)!
      Surfs are as tough as old boots. Get it muddy!
      Cheers Ron
      It's only a hobby!
        Thanks Guys
        Looking forward to having a go.
        Ron
