Hi Guys,
I have a 1989 2.4TD, with overheating problems on long distances ( 4-5hrs). I've had the radiator core replaced and the cooling system tested for leaks.
The report from the radiator repair shop is that water is getting through/to the water jacket???. They reckon the head gasket is blown or worse case the head cracked.
I've run the engine for a while with the rad cap off , but don't see any bubbles getting through, the oil cap has no moisture and the dip shows clean oil. No problems on daily driving.
Is there anyway of finding how bad the leak without removing the head. And if so is there anyway of sealing it, without blocking the radiator,if its a minor leak.
I'll be glad of any advise
Gerry
