all the belts seem tight however the pulley on the drivers side of the engine near the bottom is loose got a spanner on the bugger but could'nt tighten any more. doesn't squeek on start up only once warmed up and stops if you add a few revs or slap on air con tis a 93 2.4td. i ve had my share of engine trouble and don't really want any more
funny squeek
That pulley has two things you need to do to adjust it.Originally posted by Ivor Bigunall the belts seem tight however the pulley on the drivers side of the engine near the bottom is loose got a spanner on the bugger but could'nt tighten any more. doesn't squeek on start up only once warmed up and stops if you add a few revs or slap on air con tis a 93 2.4td. i ve had my share of engine trouble and don't really want any more
First loosen the pivot bolt, second wind in the adjusting bolt that moves it on the track. finally tighten the pivot bolt again
If you have reached the limit of the adjustment on that one then you have one seriously stretched belt and you need a new one. You can get them from Milners and you may as well get a complete set while you are at it.
Happened to mine then pulley just seized.Originally posted by luckyThat pulley has two things you need to do to adjust it.
CheersSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
Probably got a dud bearing.New pulley needed as the bearing is non replaceable.Originally posted by Ivor Bigunall the belts seem tight however the pulley on the drivers side of the engine near the bottom is loose got a spanner on the bugger but could'nt tighten any more. doesn't squeek on start up only once warmed up and stops if you add a few revs or slap on air con tis a 93 2.4td. i ve had my share of engine trouble and don't really want any more
Neville
