As I have posted before the new fan controller is in and running now.
I had to replace the thermo fan switch in the t-stat housing. It is now a 92 degree one. I am not sure what the old one was but I do know that it was kaput!
The toyota gauge does its normal thing that we are all used to .
Start........warm............. 1/2 way......sleep all day!
The new one is a Trisco Imperial one, so I had to decipher what deg F was into deg C.
IT MOVES
Driving around you can see the changes in temp as the T-stat does its job,
If I boot it up the hill it moves up a little then the Viscous fan does its bit.
I have not yet had the Thermo fan come on while driving, which brings me to the next funny thing
I gave the Ghost a bit of welly the other day to test my new fan on the way up to Mums place, after letting it run down on the turbo timer for 3 mins it turned off.
I was inside for about 5 minutes and when I came out and went to restart it the thermo fan came on as well and my swizzy new audible alarm.
Within a minute it reset and all was good.
My only theory is that as it was all very warm under the lid the T-stat housing got a bit of "heat soak" while the engine was off, because as we all know even at idle the Viscous fan throws a bit of a draught over the whole thing.
Hmmmm sounds like a good enough excuse for a bonnet scoop....I' have to convince HER
though!!
Anyway enough waffling for now
Cheers and Beers
Simon.
IT MOVES
though!! Anyway enough waffling for now
Cheers and Beers
Simon.
But normal.
