Just doing some things on my Surf, and decided to do the diagnostic. The code came back as a 4, which is Coolant sensor. Now, I'm guessing that this is something I should be worried about. However, the temperature gaugue appears to work, it starts off at cool when first starting, and slowly works it way up to halfway up the gauge. It's never gone higher than that. The car has had a modified head fitted,so it shouldn't overheat. The coolant level appears to be fine.
Is there anything I should check?
