I have also been told by the local toyota dealer to replace the viscous fan with a uk spec one at £134 it's quite expensive and some importers are changing them as soon as they come into the country, I will fit one after replacing the head
It seems very unlikely that there is any such item as a UK spec fan. If there is any difference at all between a JDM fan and one supplied in Europe it can only be an adjustment. Sounds like a great way to take another 134 off the unwary.
If you want to uprate the fan unit a bit buy the fan from a HJZ80 Land Cruiser. It bolts onto the Hilux hub and has an extra blade so it moves a bit more air.
