Just rebuilt a bust engine that had thrown a valve. I had a different head pressure tested and cleaned up, changed all the shells in the lump, new rings and gaskets.
Started it up and idled for about 10mins to check for leaks amd smoke, came up to temperature as normal, normal oil pressure, nothing obvious wrong.
Let it cool and checked the coolant, loads missing... thought it may be filling up the heater matrix's, checked the oil, mayonaise central!!!!!
Took the sump plug off and a good litre of coolant came out before I got any oil.
Any suggestions??? (The lump has been skimmed)
