Crank shaft timing gears KZN185
  • Crank shaft timing gears KZN185
    HI I need the timing gears for the KNZ185 3Ltr SSRG 1996, I seem to have shed a gear tooth or two. not sure what ones yet as I have not got the gear casting off yet. I replaced the head two months ago and every thing was sweet as a nut, then I started the enging and a loud bang and a grinding noise from the front of the engine. the cam belt and pully and the head are fine. the engine runs but it is very noisy on tick over and is missing every so often. I think it is one or both bolts have sheared off and gone thought the grears. sounded like a bolt was in loose in the engine. I put it in to a Toyota specalist garage they did some things to it charged me 7
    £750, they did not do the timing gears as I asked, they were not happy me telling them what the problem was. So it looks like I will have to do it. any help would be much praised. I live in Chepstow south wales.
    I think the big problem is, is how to get the crank shaft pully off....
    Then how to re tighten the crank shaft pully nut up after wards
