Hi All
I have two toyota injector pumps that I have available to use for my Hilux 2.8 turbo conversion.
The Numbers on the pumps are:
22100 5B280
22100 6A610
Both have boost compensators and look exactly the same other than the first one having what looks like a shaft sticking out from where the 4 injector lines screw in.
Research suggests the 5B280 is out of a early 2lt and the 6A610 is out of a 2ct.
Does anyone know if the 2ct pump can be used on a 2lt or 3l engine?
Are the internals of the pumps the same?
Does anyone have any suggestions which would be best to use on the 3l engine?
22100 5B280
22100 6A610
