Hi, anyone know if the rear seal under the distributer can be changed in situ?
Anyone changed fuel pump seals in situ?
That's crazy removing pump and not doing that seal. Been looking for the topic about doing that seal but the search feature here sucks.Originally posted by JTroc View PostJust got charged 7 hours labour for changing all the other seals and now this one pops when they put the pump back in. They refused to change the rear on in case fuel pump innards spewed out.
Nev.
Yeah it's bs they didn't do it, nothing I can do about it though. I'm sure it can be done in situ. Need a little guidance about what's behind those 4 bolts. Guess I could always try the ATF trick and see if that helps until I can sort something.Originally posted by NiftyNev View PostThat's crazy removing pump and not doing that seal. Been looking for the topic about doing that seal but the search feature here sucks.
Nev.
This is what's under the distribution block -
http://www.hiluxsurf.co.uk/showthrea...mp+seal&page=3
I can send you a PDF file of the pump if you supply an email address.
Nev.
