Been running on 50/50 veg oil and ulsd for the last 2k or so. Have now noticed the engine a bit rattly on tickover or when labouring. The noise is similar to a big end rattle but there is no sign of it when running normaly. Oil level/pressure is ok. Assuming the tappets are ok (haven`t checked yet) could it possibly be a blocked injector? By the way, it`s a 2LTE engine.
Cheers, Ken
Cheers, Ken
Just to keep you all up to date - have stopped using the vegoil and things have quietened down again. I`ll try Lucky`s suggestion of changing the timing at a later date but for the time being i`ll stick to just plain ol` diesel. I only do very low mileage at the moment, so the savings are not that great.
