My 2nd gen has an issue when driving, I think it's something to do with the turbo but my wife thinks it's manifold or exhaust related.
When we're driving, everything is fine under 1800 rpm, as you accelerate and put your foot down though, there's a noise that I can only describe as some sort of growling ( can be heard inside and outside the car ). The sound continues until the rpm climbs to the next gear change ( it's an auto ), then disappears altogether, this continues until it's in top gear, then at 55 or 60 mph ( or anything above 60 ) it's there constantly but not as loud.
My wife thinks there might be a crack in the exhaust manifold / exhaust itself or an air leak somewhere. I've looked for any signs but there aren't any, all pipes and hoses are as they should be and no sign of any cracks or corrosion on the manifold or exhaust.
I think it might be the turbo on its way out.
Is there any surefire way of checking for turbo issues?
When driving, the noise is coming from under the bonnet, directly in front of the driver ( which is what makes me think it's the turbo ).
It's a 2.4TD by the way
