Surf 2.4 ln130 will not start
  • Surf 2.4 ln130 will not start
    Hi guys
    This is my first post on here, and I have a problem with my Toyota surf ! It cut out and will not restart ! (no fuel at injector pipes) it has been running fantastic up until this happened, no warning, no noises, just like I had taken the ignition key out.
    I have tried another ECU and there are no faults when I have checked the diagnostics light etc
    Is there any of you guys that live in Bristol UK that could shine a light on whats wrong please
    many thanks
    Paul
    KISS
    first are the batteries ok and you can turn it over ok?
    You say you have no fuel at the injector pipes
    do you have fuel at the fuel filter and is it primed ?
    Undo the fuel filler cap a bit does it hiss?
    Eat.Sleep.Surf.Repeat.
      Hi Shokenore
      Thanks for the reply !
      The batteries are fine, and in times gone bye, when its been very cold and havn't used the car for a while, when the batteries have been down it has still started ok
      The fuel filter was full at the time it broke down and still is and the hand primer is also fine, it goes hard after a couple of pumps and vacuum pressure on release of the fuel cap !
      I am still convinced it is an electrical fault somewhere, but where and what ?
      I have also put a jump lead on to the engine because I have read somewhere that the earth leads break at the back of the cylinder head but to no avail.
      All the dash warning lights are working including the glow plug light, I have also checked all the fuses
      Any help would be appreciated guys, getting fed up with it now, seeing that it broke down in July ?
      Many thanks
      Paul
        Ok
        what voltage do you have at the spill control valve?
        3-5 v from memory
        Just to refresh when cranking it over have you one of the feed pipe to the injector cracked off?
          Hi again, Thanks for sticking with me on this
          Havn't measured the voltage at the spill valve yet because I need a volunteer to crank it over when checking it, (from what I have found out on the forum the ECU will send a pulse to the spill valve only when it is being cranked over and obviously when it is running) will find some help over the weekend and let you know what I find
          And yes I have left number 1 injector pipe loose in anticipation !
          many thanks
          Paul
            Cool beans
            you could just jerry rig up a bit of flex and stick it in the connector and the other end to you test probs then stick the multimeter where you can see it.
              LOL Now that's a good idea
              why didn't I think of that ?
              Probably because all I feel like doing to the surf at the moment is setting fire to it ?
              Will get some wire and try that on the week end
              I suppose if we do get a normal reading from this test, it will prove that the ECU is working and probably ok and point to the spill valve itself.
              I hope I don't have to remove that pump again ! have already done that twice in the past due to fuel leaks
              I have in my mind that it may be something to do with the immobilizer but I could also be wrong LOL
              Nice one
              Paul
                It's always easier when stood back from an issue
                Immobiliser link that s!hit out !!!
                Fingers crossed
                  Where would you start with ripping that out
                  where does the wiring go and there seems to be lots of it, havnt traced any of those wires yet, looks like a nightmare
                  Paul
                    Aftermarket ones could be anywhere
                    Check the spill control valve wiring first.
                    see if there any link wires tucked away or they may have stuck it up by the windscreen wiper motor.
                    Or
                    They may have wired it in near the ECU.
                    I dont think the pump has to come out to change the spill valve.
                      I have managed to check voltage at wiring connection going to the spill valve and it is reading 7 to 8 volts ! Is this about normal ?
                      Paul
                        um I was under the impression it was 3-5 volts and would rise with throttle position.
                        Perhaps your spill control valve is US
                        do you know what the resistance is on the valve ?
                        Just checked a spare valve and I have 1.7 ohms across the wires.
                        So just to check trying to start you wait for the glow plug sequence to finish
                        you should hear a click and you should see a slight change in the voltmeter guage.
                        Then you try to crank it?
                        How long are you cranking for?
                        And
                        is this accompanied by any smoke out the exhaust?
                          Checked the resistance of the spill valve and its 1.7 to 1.8 also rechecked the voltage going to the spill valve and when cranking the engine over its 7 to 8 volts !
                          Reconnected all back together and still no fuel at injector pipes ? Fuel system filter and pump full of fuel but nothing no smoke and no fuel ?
                          Paul
                            ok
                            crack off the banjo on the fuel pump from the fuel filter and see if you have fuel there?
                            Bit wierd though and I can understand what a complete ball ache all this grief is
                              Hi Shokenore
                              Already tried that several times, even the AA man done the same at the time it broke down ? but she just don't wont to start ?
                              anymore suggestions before I buy a gallon of petrol and put it out of its misery
                              I have had it sort of running on carb cleaner just to rule out other aspects (they don't like easy start)
                              cheers
                              Paul
