First post, so hi!
Currently driving a 2.4 Surf around Australia, done a good 30k km or so in the last 6 months and it's only had a couple of niggles in that time.
in the last 3000km or so something is getting very noisy in the fuel pump/cylinder one area, sounds like the exhaust is blowing but it's on the inlet side of the engine. I'm pretty handy with a spanner and there's nothing obvious wrong in that area.
Additionally it's getting harder and harder to start, we've often needed to warm the glow plugs up a couple of times since we've had it but now I can warm them up 6 or 7 times and it makes no difference. It will crank for 10-15 seconds and not even start trying for 3 or 4 attempts, then it will start spluttering into life but not firing properly. It eventually goes and will run all day (literally) but noisy as above.
It does stutter at steady low speeds/idling along where it didn't before, but runs as well as it ever has at motorway speeds.
I would say glow plugs but it's not really much easier to start even if I've only switched it off to fill up (it is a little easier still takes too much cranking).
Things I would note - pretty sure the head gasket/head has gone, but if it has, it's been gone for some time, doesn't overheat or suffer any of the usual ill effects of a shot head, just makes the coolant a little foamy.
I've tried pumping the plunger on the fuel filter to no avail.
Currently running injector cleaner through it.
Oil and filter has been changed fairly recently.
It doesn't use fluids excessively.
Fuel consumption may be up a fraction.
We have moved south, it's a lot colder here than what the car has been used to.
Yes I have tried Googling it and trying what it comes up with
Thanks in advance!
Thanks in advance!
Good luck with it.
