Hi guys been chasing gremlins out my hilux surf 2.8 1991 . Changed glow plugs primer pump _ put no return valve on to fuel lines checked fuse and amp on plugs are fine but only for 3 seconds i thought it was meant to be more like 12 seconds . Is there a timer that i can change or is it the glow plug relay i need to change any help would be appreicated? I currently have to pre heat three times and it runs lumpy for a few min and is fine. Starts up sweet as you like and drives great.
What do i need to change?
