Can someone point me in the right direction, my 2.4 TD Surf SSRX is playing up. On approaching roundabouts, corners, in slow moving traffic or when idling, it judders, splutters, and runs very roughly with black smoke from the exhaust then cuts out. Please can anyone help?
Engine cuts out on low revs
First up I'd change the fuel filter and check the air filter. Then check the intake tubes for oil and splits, then look for loose vacuum hoses and toss a can of Redex in the fuel tank.
Sounds like it just won't tick over happily.4x4toys.co.uk - Keeping you on and off the road...
try the above but could be a stuck EGR, gives same symptons.Originally posted by TonyNFirst up I'd change the fuel filter and check the air filter. Then check the intake tubes for oil and splits, then look for loose vacuum hoses and toss a can of Redex in the fuel tank.
Sounds like it just won't tick over happily.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
