Hi there,
Been having some trouble starting the Surf for the last few months, needed to turn the ignition until the beep 4/5/ times and then it would start. Obviously I put this down to needing new glow plugs and got around to fitting them the other day. Initially I thought the problem was improved, but now I've had to accept that it isn't, this morning it took 5-6 attempts before it started and was lumpy when it did.
I'm just looking for a checklist of things to check really. On the list so far is;
Glow plugs
TPS
Anything else I should look out for?
Many thanks.
Glow plugs
TPS
Many thanks.
