I have a 3 litre v6 4runner that died so i'm taking the breaks off and putting them on my 2.4 surf whose brakes are kaput. The calipers look wider not managed to get the disks off yet but they look kinda different, anyone know if they will fit?
brakes from 3.0 to 2.4
the disks do look deeper on the surf, its one of the older ones with the writing on the front not the badge think the disks arn't gonna do it calipers look like they would fitOriginally posted by wishbone View PostI'm pretty sure the pre-facelift surfs had smaller discs. Check on roughtrax in the brake section to confirm.
It might be easier to swap the comple hubs, discs and calipers - I know the pads are different between the models too. (just undo the 4 nuts top and bottom that hold the balljoints to the arms, undo the 54mm hub nut and slide the whole lot off) - Bit more work than that but you get the gist.
or compare part number with something like this site:Originally posted by wishbone View PostI'm pretty sure the pre-facelift surfs had smaller discs. Check on roughtrax in the brake section to confirm.
http://toyota.epc-data.com/
thats a top idea! il have a look tomorrowOriginally posted by wishbone View PostIt might be easier to swap the comple hubs, discs and calipers - I know the pads are different between the models too. (just undo the 4 nuts top and bottom that hold the balljoints to the arms, undo the 54mm hub nut and slide the whole lot off) - Bit more work than that but you get the gist.
