I know I keep posting new threads but my problems just keep changing. Recently I've been having starting issues, wouldn't fire up cold very easily and now with the warmer temperature it misfires pretty bad on start up. I put in new glow plugs and it was worse so I put the old ones back in, they still tested good. Fires up nice with one glow plug cycle but after 10 seconds starts misfiring. clears up after a while but starts misfiring again. Once warmed up the truck runs and idles fine. There is lots of black smoke when it is misfiring. The starting problem appeared out of nowhere but the misfire got much worse when I adjusted the fuel pump (timing marks on the cover and pump were not even close, timing belt is lined up perfectly).
What I have done to the truck lately, in order (2LTE engine)-
New fuel primer and one way valve on tank
New injectors, truck was starting well at this point
-One month later (I had moved so almost 3000kms later) it started having troubles starting without being plugged in.
New glow plugs, problem worse, put in old glow plugs after testing them
New fuel filter and Oil/filter change
New air temp sensor
New coolant sensor (on the intake side of the block)
Found loose vacuum line, plugged into vsv, drivability stayed the same but had an idle problem when warm
EGR was blocked off with plates but I removed it completely, and made thicker plates
Deleted VSV system and hooked up vacuum hoses as per the write up I found (warm idle problem gone now)
Checked timing belt
Fixed fuel pump timing
-This is where the startup got really bad.
Disconnected batteries for 4 hours with headlight switch "On"
I'm starting to lean towards a bad fuel pump (new one was put in 4 years ago), or maybe a sensor. I can try to get photos later, maybe someone can spot something out of place?-
I'm living kind of in the middle of nowhere and it's my only way to get around. Out here there's no one that would know anything about fixing a diesel Toyota. I'm a diesel mechanic but I'm just totally stumped and stressed out.
The truck is not losing any coolant, engine was rebuilt 30,000 kms ago with a new complete head. and new turbo. Not losing any oil, no fuel leaks, turbo boosts well and spools quite quick after the VSV/EGR delete. Really need some insight on this, thanks.
EDIT: Pictures
New air temp sensor
Checked timing belt
EDIT: Pictures
