I've been having a lot of trouble with my truck as of late. Currently experiencing a starting problem. I've been checking everything I can think of. I found what looked like a broken wire as I was trying to inspect my temp sender on the block (above starter). I thought this must be an issue but remembered seeing that when I did my engine rebuild a couple years ago so it is probably not my new problem. I did find the temp sender I was looking for and it is clearly broken, this "wire" is actually a chunk of the sender. I'm just wondering what problems this broken sender could cause. I plan to replace it anyway so I would also like to know if anyone has the part number for it or preferably if anyone knows what other Toyotas used the same sensor? I'm in Canada so when I walk into the parts store looking for diesel Toyota parts you get the
look. I usually need to give them a cross referenced part number.
EDIT: My phone had died so I couldn't take a picture. but If anyone is confused as to which sender I want, it is the one Nev has circled in this thread: http://hiluxsurf.co.uk/showthread.ph...erature+sender
