Hi all. Could do with any ones advise on this one. Yesterday my 2.4 surf started misfiring and deisel smoking quite badly. I assumed that an injector was not blowing off properly so i bled the injectors off. No air in the injectors but number 3 injector seemed to be the one that was playing up so i parked the truck up.
This morning it seemed ok untill it warmed up,then i got the same problem. The water system is pressurising so i ran a block test on it to find exhaust gasses in the coolant system. The engine is not over heating but steam is present in the exhaust gasses. Is this sounding like the dreaded cracked head syndrome???. Any advise would be greatly accepted.
cheers Steve.
cheers Steve.
