I will be moving soon and need to know if this is possible with my truck or if I'll get myself into a lot of trouble. The trailer will probably be sitting at 1200kg and is a tandem axle.
I've read some threads and it seems possible but you guys seem to be towing in better weather and with less modded trucks. Here's my specs,
1992 2.4 Turbo
rebuilt engine with new head
turbo wastegate spaced to 14 psi (with boost gauge)
2.5" straight pipe exhaust
EGR delete
5.29 gears, welded rear diff
35x12.5" tires on 15x8 aluminum wheels
automatic transmission
4" suspension lift, 3" body lift
I have a custom rear bumper with the tow point built into it. I had the trailer rental company look it over and they said it is strong enough and will tow flat with a 12" drop bar.
I've been having problems with my injectors for a long time now (received the wrong ones, got new ones and one was stuck open when I got it) so it has been gutless and I have my doubts. I have 3 new injectors in it now and it's just sitting until I get my new injector, then I have to leave. It will be a 2000km trip from central Canada to western Canada over 2 maybe 3 days. Just wondering if anyone has experience towing this far with a surf. Average temperature will be around -15 celcius so I don't think I should have problems with engine temperature. I'll be changing the oil before I leave and bringing lots of extra coolant as well as spare fuel filters. I have a coolant gauge on the dash, I really wish I could get that wired up before I leave.
1992 2.4 Turbo
EGR delete
starting to worry a bit.
