a light has just come on saying T-BELT any idea's what it is guy's
got a dash light need help with
How many miles does your Surf have on the clock? It normally comes on when you pass a milestone. Mine came on at 200000Km
As said above...if done recently...reset it (pull out the rubber grommet, on the dial shield, and press the button - on ignition or something). If not...get it doneLast edited by Sylux; 26 October 2013, 18:45.
Originally posted by les ward View Posthad dash out to fix rev counter then it came on but its at 89oookm,s
is cambelt a hard job? can a hobby mechanic do it or do i send it in to get done?
But on the whole easy enough.
You just have to take a load of stuff off first that is in the way.
Well worth getting a water pump and a crank seal at the same time, like Nev said.Eat.Sleep.Surf.Repeat.
Originally posted by Sylux View PostYou'd think a pro mechanic would at least manage to get that right. I'd have thought it was bread and butter stuff for them.
Pretty shocking they don't
Another example is a Toyota dealership that did the belt on the work Hiace bus. Four weeks later they got it back after an engine rebuild. They got the belt timing wrong, or something else and stuffed it.
BTW, I have no formal training as a mechanic, but have come across quite a few who are supposed to be trained that I could teach a thing or two.
Nev.Last edited by NiftyNev; 28 October 2013, 08:33.
