Connected the air filter again and made sure that all sensors and all plugs are connected, started it up and although difficult to start, it did start on it's own without the help of any aerosols lol. Still seemed a bit off though, so, Removed the timing cover again and spotted that when the crank and can timing marks were lined up, the IP mark on the pulley was sitting a little bit before the mark on the housing. loosened the timing belt and tried to adjust the IP pulley by one tooth, now when the crank and cam marks are lined up the IP pulley mark sits a little after the mark on the housing.
Does the timing mark on the IP pulley need to be lined up precisely?
Is there any way of locking all the pulleys in place so I can just slip the belt over them?
