Where to begin...
Well thanks already for the wealth of information this forum has provided me with already, it's been incredibly useful when undergoing recent work.
I have a few problems though that I must have caused when doing this work, the original problems were a fuel leak, from the pump, and an oil leak, from the head gasket. These are no longer an issue; I stripped it down, replaced most of the outer seals in the fuel pump (wasn't brave enough to take it fully apart) and replaces the head gasket. Now I have new problems:
The first problem is an awful engine knocking noise, It occurs when ticking over and driving normally, but not when you lift off approaching a junction, it's quite loud and very noticeable. I have a feeling it's the fuel pump out of time, however we're pretty sure it was spot-on when replacing the timing belt cover, are there any sensors that detect the angle of the pump that could have been damaged?
The second problem could be more than one issue; the oil pressure gauge is measuring nothing, not a blip, this leads me to believe it's a damaged pressure sensor, though I don't think it touched it. If I'm right it's supposed to be about in line with the number 4 cylinder and beside the oil filter on the 2L-TE engine?
Also the turbo is not working, no noise and no light, and the engine light is on, could these be as a result of there being no oil pressure reading?
Thanks in advance for any help,
Dave
Dave
