I had thought my engine was entirely seized because it would not crank. Following a friend's suggestion, I pulled the glow plugs and tried cranking it. It spat out water from no. 4 cylinder and turned freely, so I took that as a hint that the jeep ain't as dead as I thought.
Cue half a day of spannering and skinned knuckles and the head is off. It looks to me like the head at no.4 cylinder has been cracked and leaking for a while going by the pitting and the size of the crack. The head is cracked on all 4 cylinders but no. 4 is far more noticeable than the others.
My question are these:
when I had my "incident" where I forgot to put the coolant cap back on, I pulled in to a petrol station and there was water coming out the tail pipe and the coolant was blowing out the filler spout. Would the cracking explain that? (along with the excess heat from loss of cooling)
Also: how can I tell if the block/pistons/etc is ok? There's no mayonnaise anywhere and the bores look smooth and clean to me. No pitting on the pistons either, not even on no. 4.
Thanks, Dave.
Thanks, Dave.
