View Post
Engine Removal
New questions
The four pics below are area's that I'm stuck with, any help appreciated.
Pic 1 - Vacuum pipes and 2 brackets, where do the brackets attach to and where do the vacuum pipes go? I'm guessing that they are all something to do with the EGR system, if so, can I just bin them or will this cause problems at MOT time. If I can bin them, is there anything I'll need to block off?
Pic 2 - I know that this sits in the bracket just visible on the lower left of the pic, but which pipe attaches to it?
Pic 3 - Looks like another throttle cable (sorry for blurred pic), I've attached the throttle cable already, can't figure out where this one goes though?
Pic 4 - Are these 2 ring connectors anything to do with the glow plugs?
Thanks in advance
Pic 1: Look between the EGR Pipe and the Throttle Cable. see the hole there? The bracket bolts in, down in that area. One VSV is for EGR Valve and the other is for Small Butterfly.
http://www.toyotasurf.asn.au/forum/v...p?f=63&t=25419
Nev.
Pic 4: They are the two terminals that connect to the Glow Plug Resistor under Intake Manifold. Make sure you connect them properly with the insulator.
http://www.toyotasurf.asn.au/forum/v...p?f=63&t=14158
Nev.
Originally posted by NiftyNev View PostPic 1: Look between the EGR Pipe and the Throttle Cable. see the hole there? The bracket bolts in, down in that area. One VSV is for EGR Valve and the other is for Small Butterfly.
Nev.
Originally posted by NiftyNev View PostPic 4: They are the two terminals that connect to the Glow Plug Resistor under Intake Manifold. Make sure you connect them properly with the insulator.
Nev.
Originally posted by RebelV8 View PostI'm not quite sure what the EGR pipe looks like (I'm guessing it's just like a vacuum pipe?), know where the throttle cable is though so I'll look for the hole in that area. Also no idea what VSV stands for, lol
Originally posted by NiftyNev View PostFirst pic. EGR Pipe is the rusty looking cast iron pipe under the glow plug resistor terminals. Bracket goes under this pipe toward rear roughly under the EGR valve.
Nev.
Quote:
Originally Posted by RebelV8 View Post
So, black first, then red with insulation between both, yes?
Yes.
Nev.
Thanks Nev
BTW, the single hose in the pic with fuel pipes goes between water outlet under thermostat housing to under manifold. It's one of two that connect to manifold. You can see one hose connection in bottom left of this pic -
http://www.hiluxsurf.co.uk/attachmen...0&d=1376773560
Nev.
