Drive belts
  • Drive belts
    Hi all
    I'm almost ready to get the engine back in to my Surf, does anyone have a picture of what the front of 2.4 engine looks like with all the drive belts fitted. PITA having to rebuild an engine that someone else dismantled before sodding off and leaving you in the lurch to do it yourself when you've never done one before
    Afraid this is as close as I can get, the belt that's on is the PAS, the loose one in this pic would have been on the Alternator you can just see in the background. No air-con on this truck.
    I'm sure someone will be along with a better pic soon.
      Thanks Andy
      That certainly helps narrow it down somewhat
        First two are Alternator/Water Pump, next is Air con and then Power Steering.
          Thanks Nev,
          that should sort it
