hi all,
need some help, our surf has started to over heat when stuck in traffic a fan on the outside of the radiator has started to kick in never new that was there!
this is the weird bit the oil pressure needle shoots down and the temp needle shoots up, then if I rev the engine needles all go to normal fan turns off all good for 5 min then starts again?
Oil and water levels are good.
thanks
Dan
thanks
Dan
