Hi, I've recently purchased a 2.4TD hilux surf. The engine is good and it runs pretty good, only problem I have is the turbo worked for about a week or so then I replaced the air filter and I now notice that the turbo light doesn't come on the dash any more and there seems to be less power when going up hills etc... When I first turn the key all the lights do come on i.e the turbo light the engine check light etc as normal so I know the light works.
My question is I have checked all the hoses for breaks etc and have found a shortish pipe which doesn't seem to connect anywhere that I can see and was wondering if I dislodged it when replacing the air filter. The pipe in question is attached to the same part as the "J" shaped boost pipe where the pipe im looking at comes out the top and J shaped one comes out the bottom. See this post for a similar looking example as I can't post attachments as this is my first post.
I hope this all makes sense and someone with a bit more knowledge than me can help.
Peter.
Peter.
