Ignorance is bliss.
Had the smell of burning oil on and off for the last few days, so had a good dig around today and found oil staining on the exhaust manifold cover plate.
Worse case I was thinking would be cracked turbo oil pipes spraying up unto cover plate.
Found the short hose from turbo outlet to inlet manifold soaked in oil, easy fix , just give it a clean up and inspect for cracks.....
While I am waiting for it to dry after giving it a good clean I pull off the hose to turbo inlet, there is a bit of oil, but not too much, then I gave the turbo spindle a bit of a fiddle.
How much play is tolerable on the spindle?
Is a diy rebuild advisable?
Anybody got a turbo spare?
