Hi everyone.
I am Adrian from Romania.
I am hilux surf owner LN130 2.4TD EFI automatic,1992 manufacture year, right hand drive.
I bought the car in august 2008 and a problem continue to persist such as very poor acceleration from 0.
Now I want tell you about few repair made:
2008 -replace head gasket, new timig beelt kit and water pump
In last month I replace the few senzors: ecu senzor, turbo air temp senzor, electric fun swich sensor ( all sensor are genuine toyota)
-Transmision oil replace (dexron III genuine toyota)
-transfer box oil replace.
Now, what hapen!
I don't feel nothing change. ECU was reset
My hilux simptoms is Intermittent. Have good day and bad day.
Good dey: perfect cold start and good running and increase in speed with minimal throttle. very little trashed and low consumption, about 13-14 liters/100Km Urban
Bad days
perfect cold start but slow acceleration. Litle more good wen the engine is coold. when the engine become hot (normaly hot) starting away becomes difficult and cumbersome and speed increase slowly. The engine sound is like I try to tow a very heavy trailer, it is exactly sound and consumption increase over 18 liters/100km.
At this point if you want to climb a curb fail. machine speed increases slowly and progressively until somewhere over 2000 rpm, the turbine wheel frame but get stuck in the headboard. I tried this and in low range L, nothing changes. If you want to straddle the 30cm curb must act from low range transfer box.
No black smoke
I noticed though that when the air is cooler works better ( all filter was changed)
Has anyone a similar problem?
Thank you very much and waiting your opinions
Now, what hapen!
Bad days
No black smoke
