Hello
because I have a little problem now that my Toyota diesel loses, I have replaced all pipes and seals of the diesel pump and investigated. Unfortunately, it looks as if the soup from the toothed belt wheel comes (the small O-rings) seems to be broken.
Now I have front built everything out and freely set the timing belt, but I get the nut of the wheel which sits on the diesel pump where the timing belt it runs not loosely.
Has a tip for me how this mother who can cause without broken what to do, so that I can remove the pump complete to the O-rings to change.
Thank you and greetings
Martin
Martin
