could somebody please tell me where the glow plugs are located, im not mechanically minded so I don't know what or where to look. I have got a K reg 2.4 td SSRG , are there different types of glow plugs or are they all the same because I don't know what glow plugs are in my surf???
glow plugs
If you look on the left hand side of the engine by the rocker cover you should see the four injectors. Near to each injector is what looks like a post sticking up with a slot in the top. All these should be joined by a metal strip with a wire bolted on in the middle of it. These aere the glow plugs.
