Vacuum/oil pump oil seal
  • Vacuum/oil pump oil seal
    Hi all hope you are all well
    I found a bad oil leak coming from the vacuum/oil pump attached to the front of the alternator on my 97 import 2.4 td. I have removed said pump and found what appears to be a triple seal oil seal inside, really dont want to fork out £170 for a new alternator with the pump for the sake of an oil seal, does anyone know the technical term for a triple seal oil seal or where I can acquire one? Tried the net and no joy.
    The size is 20mm x 32mm x 6mm
    Amy help is much appreciated thanks
    ALL THE GEAR!............no idea!
    Far easier to just buy a good used alternator.
    Rob.
      Yeah your probably right, but its in bits at the mo as the head is being skimmed/pressure tested so i have the time, it can't be that difficult to find a seal surely !!!!
        Just go to Toyota with your Model and Frame number and get one. May as well get the o-ring as well.
        These are on hundreds of different vehicles so should be easy to get.
        Nev
