Ok, so I found loads of info on here about doing a cooling system drain, flush and refill and I was feeling pretty confident about doing this a little later in the year when the weather is better.
That was until my heater decided it was getting cold outside so it was time to give me luke-warm air inside the cab instead of toastie niceness
Anyhow, before I go and freeze my nuts off doing the deed (not that one, she's not up for outdoor shenanigans
) a few quick questions.
1) I see Roughtrax do the red and green Toyota coolant and wondered what the difference is? I know you can't mix between the two but as I'm flushing the whole system which would you suggest and why?
2) Also on the subject of the above coolant (may sound st
pid but I want to be sure), what ratio of red or green coolant stuff should I be mixing with distilled water - I've read 50/50 is this right?
3) And lastly, what does this little jobby do?
I know it has something to do with the heater system (thanks to Wishbone's post http://www.hiluxsurf.co.uk/showthrea...coolant&page=2 ) but it doesn't move when I move the heating controls from blue to red, should it?
Thanks for looking.
Thanks for looking.
