Taken up the slack in the throttle cable and I would like to confirm the adjustment on the kickdown cable..
* Throttle at wide open position
* metal float on kc should protrude 0-8mm from the end of the rubber boot
Even after throttle adjustment the kc adjustment looks correct but I can still pull the cable another 20mm until the lever on the gearbox bottoms out, is this just normal free play in the lever?
Much apreciated!
Much apreciated!
