Lower than normal coolant temps
  • Lower than normal coolant temps
    Hi.
    When I first got my truck, I fitted a temp sensor in the top hose to keep an eye on coolant temps - as I was paranoid about the LN130's head.
    (Fat load of good that did me, as when it went last year, it went with no warning)
    I got used to the temps being 85-89 degrees both before and after the head repair.
    A few weeks ago (and several thousand miles after I fitted a new head) I noticed that I have 67-71 degrees now - should I be worried? What does this mean?
    Could this mean that the coolant pressure has increased for some reason and reduced the temperature? Heaters, MPG, performance, all unaffected.
    Am I just paranoid?
    Sounds like your thermostat may be stuck open
    Always up to my neck in it
      Mabye viscous fan is coming on earlier or seized. Did you change rad with head repair and have you fitted a new possibly lower temp thermostat?
      well, that was a bad idea!
        due to outside temps being so low? my top hose guage runs colder the cooler it is out side, but engine temps remains normal
        www.apmautos.com
          thanks for your replies.
          I don't think the thermostat is stuck open - I can see the point it opens as the water gushes over the top hose and the temp shoots up.
          The lower temperatures have not really affected it as I don't see much fluctuation over a few degrees between summer and winter.
          Viscos fan - hmmm. That's worth checking out. I did replace that with the head (I broke the old one getting it off) so I'll check that out.
          I guess I should also double check the calibration of this digital temp gauge with some boiling water, as it could be giving bad readings.
            I have added some cheapo ebay self-adhesive heat-shield to the turbo.... I can't see that reducing the coolant temp by 15 degrees though....
            Truck is running really well, maybe I should just relax....
