Big trouble 2.4 manual
  • Big trouble 2.4 manual
    Hi guys, does anyone know if over fuelling & a discharge of grey smoke could be caused by a dodgy fuel tank. thanks in antisipation.
    A fuel tank cant cause overfuelling more likely to be the pump
    well, that was a bad idea!
      is it a tubo ? if it is look at the airflow metre this will make it give the impresion it is overfueling if its lost power and heaving smoke out is the turbo working ?
        I have the egr mod on mine and it's very smoky until it hits running temp. I never did the egr mod, so don't know if there is anything can be done to upgrade the ecu or anything?
        What comes around goes around!!
          Also, must add, a car at very low fuel level will smoke, but more white smoke then light blue over fuel colour
            Fuel Filter
            When was your fuel filter last changed? I had similar problems and it was my fuel filter.
