Weird Rumbling Noise
  • Weird Rumbling Noise
    Hi guys, long time no see! Hope you're all doing good! Finally found the time to actually post something on here! Unfortunately, it's a request for help! No, I'm not going to be one of those guys that only stops by when they want something! But I do need your help. The Surf is a 1991 (H) LN130, it's the pre-facelift model with the 2.4 engine. It's been fine, but suddenly (very suddenly) I am noticing a serious rumble which seems to be coming from the back end when I reach about 35-40MPH. It feels similar to what you get if your front wheels are seriously out of balance, only at the back, and much more pronounced. This appeared literally over night, not after a heavy off roading session or anything. So far I have checked the diff oil, which is OK, lifted it up and shaken and rotated the rear wheels, and all seems to be ok, or at least not noticeably malfunctioning. I noticed the bump stop on the R/H rear spring has fallen off (it's still inside the spring rattling around on the bottom) which of course I will fix but I doubt this is the problem as the shuddering/rumbling is quite severe, you can both hear and feel it. Any ideas?
    Thanks in advance for any light you guys can shed!
    Propshaft UJs?
      Or an out of shape tyre
      well, that was a bad idea!
        Thanks for the replies so far guys - I forgot to mention there is some slop in the propshaft and it hadn't seen the grease gun for a while so I greased her up. The tyres look fine condition wise, although it's not impossible for this to be the problem. This is actually my mothers partners Surf, not my own, I could swap the wheels with mine to check I guess.
          Propshaft UJ it was
